Maintenance and Care for a FLUX Series Smart Trainer
FLUX Smart trainers are designed to be maintenance free. Over time it is possible for the trainer to generate a bit of noise. This FAQ is designed to solve most noise related issues.
Free hub greasing
A cracking sound when riding can be due to the need for the axle and cassette body needing grease. In addition we also recommend the cleaning of the cassette. This process should be performed on an annual basis.
Listen here for an example: Cracking sound when riding
Tools needed:
- 5mm allen key
- Grease
Instructions:
- Use the 5mm allen key to remove the free hub including the cassette from your bike trainer. Both free hub and cassette can be removed together.
- Remove the black cylinder from the axles and grease the inside and outside.
- Place the cylinder back inside the free hub and re-assemble the free hub and cassette on the bike trainer. Make sure the cassette and free hub are tightly secured.
