Downloading Golf Courses to Your Watch Using the Garmin Connect App
Some watches that support the Golf activity are not preloaded with golf course maps. For these watches, golf courses are downloaded, installed, and updated through the Garmin Connect app instead of Garmin Express. Once downloaded in the Garmin Connect app and added to your watch, your watch will display the 5 closest courses based on your watch's GPS location.
Although courses are downloaded individually through the Garmin Connect app instead of through Garmin Express like devices that have preloaded mapping, the course information will be identical.
Downloading Golf Courses From the Garmin Connect App
  1. From the Garmin Connect app access the menu:
    • Android: Select Three Horizontal Lines (Upper left corner).
    • iOS: Select More (Lower right corner).
  2. Select Download Golf Courses.
  3. Select + (upper right corner).
  4. Search for a specific course by name.
  5. Select Download Icon next to the desired course.
    • The course list will be based on distance from your phone's last known GPS location.
The course will now be saved in the Connect app, and is ready to sync to the watch when you are at the course. See the steps for adding golf courses to the watch for steps on transferring the course from the Garmin Connect app to your watch.
Deleting Golf Courses From the Garmin Connect App
The Garmin Connect app can store up to 100 courses. If you have reached the limit, select the option below for steps on deleting courses from the Garmin Connect app.
  • Android: Press and hold the course and then select REMOVE.
  • iOS: Swipe left on the course and then select Delete.
Adding Golf Courses to the Watch
  1. Select Start/Stop or Action key.
  2. Select Golf.
  3. Allow data to transfer.
The device will now show the 5 closest courses based on your watch's GPS location. Select the course to be played, and the full course will be downloaded. The most recently played golf course will remain cached on the device once it is downloaded, and can be accessed without the need for a Bluetooth connection.
Relaterad
