Edge 1050 Battery Life Expectations
The battery life of your Edge® 1050 cycling computer may be impacted by the usage of features within the product or the way it is used. The information in the table below is presented to help outline the conditions used to determine the estimated battery life specification. The additional usage of these features or other features not included below may result in reduced battery life. The information presented below is presented as a general guide for reference only on the Edge 1050 model.
| Use Case Description | |||
| Low | Battery Saver | Demanding | |
| GPS Setting | GPS | GPS | Multi-GNSS Multi-Band |
| Number of Paired ANT Sensors | 0 | 2 | 4 |
| ANT Sensor Type | N/A | Speed, Cadence | Speed, Cadence, Heart, Power |
| Phone Paired & Connected | No | Yes | Yes |
| LiveTrack Enabled | No | Yes | Yes |
| Backlight Brightness1 | Auto | Auto | Auto |
| Backlight Timeout | Stays On | 15 Second | Stays On |
| Notifications Received Per Hour | 0 | 4 | 8 |
| User Interface Interactions Per Hour | 5 | 10 | 15 |
| User Interface Configuration | Activity Timer Page | Activity Timer Page | Map Page |
| Following a Course2 | No | Yes | Yes |
| Operating Temperature Range | 10C - 40C | 10C - 40C | 10C - 40C |
| Estimated Battery Life | Up to 24 hours | Up to 60 hours | Up to 20 hours |
The usage of a Garmin Varia Rearview Radar with your Edge device may result in an additional reduction in battery life. This potential, additional reduction in battery life will vary depending upon traffic conditions and the number of vehicles in the vicinity of the radar device during operation.
1 In Auto Brightness mode, the Edge 1050 display backlight will automatically adjust its brightness based on ambient light conditions, and battery life is impacted accordingly. The battery life estimates are based on average riding conditions. Note that in Manual Brightness mode, higher backlight brightness settings will decrease battery life.
2 Each course is unique regarding the number and type of alerts generated. The number of alerts generated by the course will impact battery life. Courses that generate a large number or frequent alerts will consume more battery life than courses with fewer turns or alerts.
