Creating, Editing, Or Deleting a Trip On An Automotive Device
Creating a multiple-point trip allows navigation among several points. Trips can be saved to the device's internal storage for use at a later date by using Trip Planner. The device will store up to 100 trips.
To create a trip:
1. Tools
2. Touch Trip Planner
3. Touch the Plus
4. Touch Select Start Location. (Note that the Start Location is not necessarily the point from where you'll be leaving. The Start Location will be the first point you would like to travel to).
5. Locate the desired starting point using the various search options
6. Touch Select
7. Touch the Plus to add a second point
8. Follow steps 5 through 7 to locate and add up to 30 total points
- To adjust the order of points as you add them, touch and hold on the point you'd like to move, then drag it to the desired location on the list
- To remove points, touch
and the point you would like to remove and touch Delete, repeat with further points if desired
9. When all desired points have been added, touch Next
10. Type the desired name for the route, then touch Done. The device will now calculate.
11. The route is saved to the Trip Planner automatically
To edit or delete a route/trip:
- Touch Tools
- Touch Trip Planner
- Touch the name of the route you would like to edit
- Touch
- Select from the following options:
- Edit Destinations: Add or remove points from the route
- Optimize Order: Have the device calculate the most optimum order in which to travel to all the entered points.
- Note: The start point and end point will remain as entered and will not be changed when optimized.
- Delete Trip: Removes the trip from Trip Planner
- Rename Trip: Customize the name of the trip as it appears in Trip Planner
When the route has been edited to your satisfaction, touch Go! to proceed with navigation.
