The Time on My vivosport Is Wrong
vivosport receives the time that it displays from either the Garmin Connect app on a smartphone or from Garmin Express on a personal computer. If the time on your watch is not correct after you have completed a sync with either of these programs, this would indicate that the time setting on the device is set to Manual instead of Auto. To correct this issue, take the following steps:
I've sync'd my device and my time is still wrong
Make sure that the Time Source setting on your watch is set to Auto:
Wake up the display on the watch and swipe the touchscreen
Hold the touchscreen to view the menu
Select
Select
Select Set Time
Select Auto
If the time was set to Manual perform another sync. This should correct the time on your device.
- A sync via the Garmin Connect app should automatically occur once you open the app. If one does not occur, touch the sync icon from the upper right hand corner of the My Day screen. If you are still unable to sync via these methods please review our Bluetooth Troubleshooting FAQ for additional assistance with connecting your paired device with the app.
- If you are encountering an issue with syncing using Garmin Express please review the following FAQ: Troubleshoot Syncing with Garmin Express
