Getting Started With the Garmin Messenger App
Garmin Messenger™ is an Android and iOS mobile application that optimizes inReach® satellite messaging to use the cellular connection of your compatible smartphone when it's available, then switches to 100% global Iridium satellite connection with a compatible inReach device when you go beyond available cellular coverage range. Friends and family can also use the app to stay in touch with inReach users.
When you first set up the Garmin Messenger app, you are prompted to verify your mobile phone number on the mobile phone that will be used. From that point on, any inReach messages sent to your phone number will be routed to the Garmin Messenger app instead of your phone's default text messaging app.
The Garmin Messenger app can be downloaded for free from the app store on a smartphone.
Features of the Garmin Messenger App
What the Garmin Messenger app can do is based on having a compatible inReach device, or no device.
Without a Compatible inReach Device
Send and receive messages using the cellular connection of your compatible smartphone.
When you allow Garmin Messenger to access your phone contacts the app will check for other Garmin Messenger app users based on their phone numbers.
With a Compatible inReach Device
Access online device support
Create and edit Contacts
MapShare™ page
Request weather forecasts
Update your inReach device software
Sync Check-ins, Quick Texts, and Contacts from your Garmin Explore account to your inReach device
Track sharing
Trigger an SOS
