Garmin Autopilot Compatibility Guide
AUTOPILOT REFERENCE TABLE
Steering Type
Vessel Size/Type and Overall UseRecommended Core PackDrive Unit TypeComponents Included in Core PackRequired Components not Included in Core Pack
Hydraulic
Premium, recommended option for most hydraulic steering installations, including Verado®, power assist and total cylinder volumes up to 24 cubic inches. Recommended for high use, rougher waters, high performance and slow speed applications. Also recommended for Evinrude G2 Dynamic Power Steering systems
Reactor™ 40 Hydraulic Core Pack with SmartPump™ v2
Part # 010-02794-01
SmartPump v2
Reactor 40
SmartPump v2
Shadow Drive
GHC 50
*3 or 5 ORB Male to 1/4" NPT female adapters
*Hydraulic hose - machine-crimped or field replaceable fittings. Minimum 1000psi
* Hydraulic T-connectors - varies by vessel
* Hydraulic Shut-off valves - varies by vessel
HydraulicLow-cost option and single-cylinder applications with cylinder volumes from 6 to 14 cubic inches
Reactor 40 Hydraulic Autopilot
Part # 010-02794-00
GHP 1.2L Pump
Part # 010-00705-64
Reactor 40
ECU 10
Shadow Drive
GHC 50
GHP 1.2L Pump
Hydraulic
A low-cost option for dual-cylinder applications with total cylinder volumes from 10 to 24 cubic inches (from 160 to 390 cc)
The 2.0L pump is a Low Pressure, High
Volume pump and will not work in a High Pressure system.
Part # 010-02794-00
GHP 2.0L Pump
Part # 010-00705-63
Reactor 40
ECU 10
Shadow Drive
GHC 50
GHP 2.0L Pump
Hydraulic
Cruising applications only and  cannot be used in low speed
applications like Trolling; for single engine outboard (150hp and below) vessels less than 25’ long.  For cylinder sizes up to 10 cubic inches (up to 165 cc)
Not recommended for fishing or applications that require holding heading while trolling at low speeds or operating in rough waters. For applications that require precise heading control, our higher-performance Reactor 40 models are recommended.  Compact Reactor uses a gear pump design with limited performance relative to similar flow piston pumps.  Not recommended for power assist installs, engines above 150 horsepower, or boats with more than 12 degree deadrise.  Mount pump within 6 feet of the steering cylinder for best results
Compact Reactor™ 40 with Pump, GHC 50™ and Shadow Drive Technology Pack
Part # 010-02794-08
1.0L Pump
Reactor 40
Compact ECU
1.0L Pump
Shadow Drive
GHC 50
Mechanical SteeringTotal vessel displacements from 48,000 to 79,000 pounds
Reactor 40 Mechanical/Solenoid/ Retrofit Core Pack
010-02794-02
Class B Linear Actuator
Reactor 40
ECU 12
GHC 50
Class B linear actuator; has rudder feedback included
Mechanical SteeringTotal vessel displacements up to 48,400 pounds
010-02794-02
Class B Compact Linear Actuator
Reactor 40
ECU 12
GHC 50
Mechanical SteeringTotal vessel displacements up to 28,500 pounds, with very low steering drag
010-02794-02
Class A Linear Actuator
Reactor 40
ECU 12
GHC 50
Class A linear actuator; has rudder feedback included
Mechanical SteeringSailboats and Powerboats with non-Garmin drive units
010-02794-02
Third-party Drive Unit
Reactor 40
ECU 12
GHC 50
Third-party drive unit
Actuator Power Cable
GRF 10 Rudder Sensor or
Rudder Feedback Cable plus a third party rudder sensor
Steer by WireDometic (SeaStar) Optimus and Optimus 360, UFlex Integra, ZF Pod Drive and Sail Drive, Yanmar JC10/JC20, Glendinning Complete Controls, Xentas, Evinrude G2 IPS
Reactor 40 Steer-by-wire Standard Core Pack
010-02794-03
Reactor 40
GHC 50
Steer by WireYamaha Helm Master (not Helm Master EX)
Reactor 40 Steer-by-wire Core Pack for Yamaha Helm Master
010-02794-04
Gateway Included
Reactor 40
Autopilot Gateway
GHC 50
Steer by Wire
Volvo IPS or Sterndrive (C3 or newer Volvo EVC Systems)
Aquamatic Sterndrive DPI
Reactor 40 Steer-by-wire Core Pack for Volvo-Penta
010-02794-06
Gateway Included
Reactor 40
Autopilot Gateway
GHC 50
Steer by WireViking VIPER
Reactor 40 Steer-by-wire Core Pack for Viking Viper
010-02794-05
Reactor 40
GHC 50
Hydraulic Hydraulic steering vessels with non Garmin drive units
Reactor 40 Mechanical / Retrofit / Solenoid Core pack with GHC 50
PN: 010-02794-02
Third-party Hydraulic drive unit
Reactor 40
ECU 12
GHC 50
Actuator Motor Cable, 010-11533-00:
GRF™ 10 rudder sensor 010-11829-00:  or
NOTE: If using a 3rd party Rudder Feedback sensor use Rudder Feedback Cable 010-11532-00
SolenoidConstant running hydraulic pump systems with solenoid autopilot control
010-02794-02
Third-party Solenoid Required
Reactor 40
ECU 12
GHC 50
Solenoid Cable
or Rudder Feedback cable plus a third-party rudder sensor
Cable SteerMost cable steered vessels
010-02794-02
Third-party 12VDC Brushed Motor Actuator Required
Reactor 40
ECU 12
GHC 50
or Rudder Feedback Cable plus a third-party rudder sensor
Auxiliary Gas Engine (Kicker)<25HP auxiliary gas engines from most major manufacturersReactor 40 KickerSteering Actuator Included
CCU
ECU
Steering Actuator Throttle
Actuator Wireless Remote
See Recommended Pump Size for the GHP Hydraulic Autopilotsfor additional information for pump selection.
The Wireless Remote with gesture control is an optional accessory compatible with all Garmin autopilots listed; requires a GHC 50, GHC20, or supported chartplotter.
Reactor Autopilot Remote Control  Part number: 010-12833-10
NOTE: The Garmin Trolling Motor Remote, part number 010-12833-00, is specifically designed to be used with the Garmin Force Trolling Motor; it is not compatible with the Reactor 40 Autopilot system.
REACTOR 40 KICKER ENGINE COMPATIBILITY
The Reactor 40 Kicker Autopilot is currently compatible with the following engines.
NOTE: The outboard motors listed below are compatible only if:
  • The outboard has a tiller handle. Outboards without a tiller handle may work with custom installation not supported by Garmin
  • The outboard has a tilt tube. Outboards without a standard tilt tube are not compatible.  Aftermarket “bolt on” tilt tubes are not supported (incorrectly positions steering actuator)
ManufacturerMotor HorsepowerYearRequired Accessories
YamahaEFI 20, 2519-newer
Yamaha EFI linkage parts (010-12826-05), Sold separately
Requires installation of stainless steel tilt tube (010-12826-03)1
YamahaCarbureted T8, T9.9, F9.908-newer
Bag #1 included with R40 Kicker1
YamahaCarbureted 15, 2007-newer
Bag #2 included with R40 Kicker
Honda
Carbureted 8, 9.9
Only motors with factory tilt tube
01-newer
Bag #5 included with R40 Kicker1
HondaCarbureted 15, 2003-newer
  MercuryCarbureted 8, 9.9, 9.9 Bigfoot & Pro06-newerBag #3 included with R40 Kicker
MercuryEFI 9.9, 15, 2017-newerBag #4 included with R40 Kicker
SuzukiEFI 9.9, 15, 2014-newerSuzuki Linkage Parts (010-12826-04), Sold separately
TohatsuCarbureted 8hp (MFS08A and up), Carbureted 9.8 (MFS9.8A and up)Not CompatibleThese outboards are not supported.  They do not have tilt tubes.
Tohatsu
Carbureted 9.9 (MFS9.9C and up)
08-newerBag #3 included with R40 Kicker2.  Compatible only with outboards with a factory tilt tube.
TohatsuEFI 9.9, 15, 20, 2517-newerBag #4 included with R40 Kicker2
1  Garmin requires replacement of the mild steel tilt tubes supplied by Yamaha and Honda with our stainless steel tilt tube.  This can be ordered as a kit or as an accessory of R40 Kicker (see accessories on Garmin.com). Mild steel tubes from Yamaha and Honda are more susceptible to corrosion which leads to damage of the R40 Kicker steering actuator.
2 For the purposes of Reactor 40 Kicker installation, consider Mercury and Tohatsu outboards to be the same.
