How Do I Adjust the Time on the vivomove 3?
Adjusting the time on the vivomove 3 including vivomove Style and Luxe can involve the digital time as well as the watch hands. Below are options covered in the Owner Manual which should be able to help you out:
If the time on your watch hands is off see: Aligning the Watch Hands
If the digital time on the watch is wrong see: My device does not display the correct time
If you need to manually adjust the digital time see: Setting the Time Manually
