確認當前內容適用於您的裝置
此文章尚未支援您目前所選的語言,您可以從下方選取其他語言。
Full Uninstall of Garmin Express/Garmin Express Fails to Uninstall
Select your operating system below for steps to fully uninstall Garmin Express™ software from your computer.
Windows 11
1. Select the Start button
windows start button screenshot
2. Select Settings
3. Select Apps
4. Select Apps & Features
installed apps windows 11 in settings
5. Find Garmin Express and select the three dots
garmin express 3 dots
6. Select Uninstall
7. Select Uninstall again
Windows 10
2. Select Settings
3. Select Apps
4. Select Apps & features if necessary
5. Select Garmin Express
6. Select Uninstall
You May Receive a Message "Windows needs to reboot" or the Uninstall Might not Work. Follow These Steps if This Happens:
Open the Task Manager by holding down Ctrl + Shift + Esc
1. Click Yes if prompted to allow Task Manager to make changes to your computer
2. Click the Processes tab
3. Select More details if the tabs are not present
4. Select Windows Update Service (if present) and click End Task
5. Select Microsoft Service Process (if present) and click End Task
6. Restart the computer and follow the above steps to uninstall Garmin Express again
NOTE: Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems. Follow the instructions below to ensure that the computer is completely restarted.
Windows 10
  1. Right-click the windows icon Start button
  2. Click Power
    • Some computers may skip this step
  3. Click Shut down or sign out
  4. Click Restart
Windows Only - These Troubleshooting Steps are for Advanced Users if the Above Does not Work:
1. Follow the steps in .msi File Not Found when Updating a Garmin Software Application, which may correct the issue before following the next step.
2. We recommend trying a different computer or getting the computer checked by a Microsoft Certified Repair Technician if you are not comfortable with these steps or these steps don't fix the issue.
Mac OS X:
NOTE: This process may delete the backups from Garmin Express. See Manage Saved Places on an Automotive Device using BaseCamp on a Mac for instructions to back up those items with BaseCamp.
1. Quit Garmin Express from the menu bar (the black triangle icon in the upper right area of the screen)
2. Click Quit in the “Keep Garmin Express running in the background?” pop-up box
3. Click the Finder icon on the dock
4. Click Go from the Apple menu bar (upper-left area of the screen)
5. Click Applications
6. Click and drag the Garmin Express icon to the Trash
7. Enter your Mac Administrator User Name and Password.
8. Click Go from the Apple menu bar (upper-left area of the screen)
9. Press and hold one of the Option keys on the keyboard
10. Press Library
11. Open the Preferences folder
12. Click and drag any files with names that start with "com.garmin.renu" to the Trash
13. Click Back to return to the Library
14. Open the Application Support folder
15. Open the Garmin folder
16. Click and drag the Express folder to the Trash
17. Click Back to return to the Application Support folder
18. Click Back again to return to the Library
19. Open the Caches folder
20. Click and drag the following (if present) files to the Trash:
  • com.garmin.renu.client
  • com.garmin.renu.service.crashreporter
21. Empty the Trash
  • If the Trash cannot be emptied, restart the Mac and try again to Empty Trash.
If the Above Steps do not Work:
  • Try using Garmin Express on a different computer.
  • Consult a Microsoft Certified Repair Technician for Windows.
  • Consult an Apple Authorized Service Provider for Mac.
相關資源
