The Gear Tracking feature in your Garmin Connect™ account allows you to keep track of the wear and tear of your gear over time, including running shoes and cycling equipment. You can track how far you have run and assign a total distance that will indicate when it is time to change your shoes. Cyclists can do the same for bikes to know when it is time to take the wheels in for service.
Adding Gear in Garmin Connect:
How Do I Add, Edit, Remove, or Retire Gear?
Select your preferred platform below for instructions to remove, retire, edit, or add new gear in Garmin Connect.
NOTE: Gear must have a first use date before or same as the date of the activity to which it is being added.
NOTE: If you delete gear from the retired gear menu, it will permanently remove the gear from Garmin Connect.
Follow steps 1-3 from the previous section.
Next to the name of a gear item, select Edit, Remove, or Retire.
The First Use field for an existing gear item cannot be edited. The Gear Type, Brand & Model, Nickname, Max Distance, and Automatically Add to... fields can be edited. When you choose the option to automatically add a specific gear item to new activities, the distance will automatically be tracked for that gear.
Garmin Connect Web
Add Gear:
From a web browser. sign into your Garmin Connect account.
Select Gear from the navigation bar on the left.
Select to add new gear.
After entering gear information, select Save.
Edit, Retire, or Remove Gear:
Follow steps 1-2 from the previous section.
Select next to the name of a gear item you want to edit, retire, or remove.
How Do I Edit the Gear Used for a Past Activity?
You can add existing gear or change the gear you used for a recorded activity. Select your preferred platform below for instructions.
