確認當前內容適用於您的裝置
此文章尚未支援您目前所選的語言,您可以從下方選取其他語言。
Types of USB Cables Used to Connect Automotive Devices to the Computer
There are three types of USB data cables used to connect Garmin automotive devices to the computer: mini-USB, micro-USB, and USB-C.
Locate the USB port on your device and reference the images below to know which USB data cable to use.
NOTE: Some of our devices have a powered mount and the USB port used for the computer may be located under the mount or in a different location. See Where to Connect the USB Computer Cable on Devices with a Powered Mount for more info.
mini-USB Port:
Some devices come with a USB data cable in the box when purchased new. A compatible mini-USB cable can also be purchased from Garmin's website
Micro-USB Port:
Some devices come with a USB data cable in the box when purchased new. A compatible micro-USB cable can also be purchased from Garmin's website.
Use a Garmin brand USB data cable to ensure the device communicates with the computer properly.
USB-C Port:
USB C Port 1
Some devices come with a USB-C cable that can be used to connect to the computer to charge it.  A compatible data transfer USB cable type A to type C can be purchased on the Garmin website.
If your computer also has a USB-C port, you can connect directly using a USB type C to USB type C data transfer cable without a converter cable. A compatible data transfer USB cable type C to type C can be purchased on the Garmin website.
Macs with only USB-C Ports:
Some newer Mac computers may only have USB-C or Thunderbolt ports. It is best to connect your device directly to the computer when possible. If your device has a USB-C port, you can use a USB Type C to Type C data transfer cable. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
Macs with M1 and Newer Chips and USB-C Ports:
Automotive devices with miniUSB or microUSB ports must use a USB-C to USB adapter along with the appropriate miniUSB to USB-A or microUSB to USB-A cable provided with the device.
Automotive devices listed below may need to use a USB 2.0 third-party hub in order for the Garmin device to properly detect the USB connection.
  • BMW Motorrad Navigator V and VI
  • Camper 760 caravan and motorhome sat nav
  • Camper 780 caravan and motorhome sat nav
  • Camper 785 & Traffic caravan and motorhome sat nav with camera
  • Camper 890 caravan and motorhome sat nav
  • Camper 895 caravan and motorhome sat nav
  • Camper 1090 caravan and motorhome sat nav
  • Camper 1095 caravan and motorhome sat nav
  • Can-Am Spyder zūmo® 590LM
  • dēzl™ 560 GPS navigator
  • dēzl™ 760 GPS navigator
  • dēzl™ 770 GPS navigator
  • dēzl™ 780 GPS navigator
  • dēzl™ LGV500 | dēzl™ OTR500 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV700 | dēzl™ OTR700 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
  • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
  • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
  • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
  • dēzlCam™ LMTHD GPS navigator with camera
  • dēzlCam™ 785 LMT-S GPS navigator with camera
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • Garmin Catalyst™ Driving Performance Optimizer
  • Garmin Dash Cam™ 45
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 54
  • Garmin Dash Cam™ 55
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 65W
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
  • Garmin DriveLuxe™ 50 GPS navigator
  • Garmin DriveLuxe™ 51 GPS navigator
  • Garmin Fleet™ 600 series
  • Garmin Fleet™ 700 series
  • Garmin Speak™ with Amazon Alexa
  • Garmin Speak™ Plus with Amazon Alexa with Built-in Dash Cam
  • Harley Davidson Roadtech zūmo® 590LM
  • nūviCam™ LMTHD GPS navigator with camera
  • Overlander® GPS navigator
  • RV 760 RV navigator
  • RV 780 RV navigator
  • RV 785 & Traffic RV navigator with camera
  • RV 890 RV navigator
  • RV 895 RV navigator
  • RV 1090 RV navigator
  • RV 1095 RV navigator
  • zūmo® 590 GPS navigator
  • zūmo® 595 GPS navigator
Macs with Other Types of USB Ports:
Connecting through a hub, USB extension cable, adapter, keyboard, or monitor is not recommended or supported.  Use the product compatible USB cable to connect directly to the computer.
相關資源
