確認當前內容適用於您的裝置
此文章尚未支援您目前所選的語言,您可以從下方選取其他語言。
Pairing the BC 30 Wireless Backup Camera Transmitter and the BC 30 Receiver
You can pair up to four wireless cameras with the BC 30 receiver cable. Your camera, transmitter, and receiver cable come paired from the factory if they were packaged together. No special steps should be required for them to pair once installed.
If the transmitter and receiver cable is properly installed and you are not receiving video on the GPS device or you have purchased an additional camera and transmitter, you can manually pair them.
Detailed Video Tutorials are Available Below:
Pairing & Troubleshooting
Pairing Additional Cameras
To Manually Pair the BC 30 Transmitter and Receiver Cable:
1. Turn on the GPS device and connect it to the BC 30 receiver cable
2. Touch Settings
3. Touch Backup Camera or Wireless Camera
4. Touch Add New Camera
5. If prompted to pair a BC 30 or BC 40, touch BC 30
6. Take the vehicle out of reverse, or disconnect power from the camera and transmitter, and select OK
7. Apply the brakes, and place the vehicle in reverse, or connect power to the camera and transmitter to complete pairing
8. Touch Yes or No to rename the camera
The transmitter and receiver cable should now be paired. Repeat these steps if the BC 30 Wireless Backup Camera transmitter and the receiver cable do not pair successfully.
See BC 30 Wireless Backup Camera isn't Working Properly for additional troubleshooting.
