Der Artikel ist in der derzeit ausgewählten Sprache nicht verfügbar. Du kannst unten eine andere auswählen.
Current Draw of the zūmo XT Motorcycle Power Cable
zūmo® XT GPS navigator:
- When the zūmo XT is NOT connected to the motorcycle charging mount, the parasitic current draw of the Motorcycle Power Cable is 150uA @ 12V.
- When the zūmo XT IS connected to the motorcycle charging mount, the current draw is Input: 10-30V, 1.5A (max) Output: 4.8-5.5V, 1.5A.
zūmo® XT2 GPS navigator:
- The current draw for the zūmo XT2 motorcycle power cable is 1.5A max, standby current draw: <5mA, and off mode current draw: <1mA.
Additional information can be found in Voltage Input/Output and Fuse Specs for Automotive Power Cables.
