Changing the Home location on a Honda Navigation System
The Go Home button on your Honda navigation system can be programmed to allow you to quickly navigate to your home location. At times, you may need to change this location or reprogram it. This can easily be done from the navigation system. See the instructions below for your vehicle model for step-by-step instructions.
2018 Accord and Odyssey
1. Touch Navigation
2. Touch Where To? (magnifying glass icon)
3. Touch Saved
4. Touch the saved location labeled "Home"
5.  Touch Info
6. Touch the menu bars (3 lines)
7. Touch Delete
8. Touch Delete to confirm
The home location will now be deleted. You can return to the main menu and touch Home to set a new location.
2019 Accord, Odyssey, and Pilot
1. Touch Navigation
3. Touch Saved
5.  Touch Info
7. Touch Delete
Other models
1. Touch Navigation
2. Touch Where To?
3. Touch Saved
5. Touch the the info button (letter i in a circle)
7. Touch Delete
8. Touch Yes
The home location will now be deleted. You can return to the main menu and touch Go Home to set a new location.
