How Do I Wire my Speakers in 2 Ohm Configuration for my 600 Series Stereo? (Parallel Configuration)
To wire 2 x 4 Ohm speakers in parallel to present a 2 Ohm load to the 600 series stereo per channel, simply follow the below diagram showing the positive terminals from each speaker connected to each other and the same with the negative terminals. When this is done, connect the positive and negative wires from the closest speaker to the Stereo.
2-Ohm-parallel
