Navigational Avoidances on a Honda Gold Wing Navigation System
Paccar Systems with Garmin navigation have an Avoidance menu where you can select various options that will adjust how your device routes you. Highlighted items will be avoided whenever possible.
To locate the Avoidance menu:
1. Search for a destination
2. Select Go To
3. Highlight the desired Avoidances under Avoid
Repeat the steps above to disable the checked Avoidance.
Available avoidances:
- U-Turns – Avoids calculating routes that require a U-turn
- Highways – Avoids highways, interstates, freeways, motorways, and other major routes
- Toll Roads – Avoids toll roads and certain specified congestion zones
- Ferries – Avoids routes that require a ferry crossing
- Carpool Lanes – Avoids lanes designated specifically for carpooling
- Traffic – Avoids traffic if a quicker route is available
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
