Syncing Amazon Music to an Approach S70 Watch
This article will provide instructions to use the Connect IQ™ app for Amazon Music on the Approach® S70. For all other devices see Loading Music to a Garmin Watch.
Requirements
The following are requirements to use the Connect IQ™ app for Amazon Music on your watch:
You must be the Amazon Prime primary account holder. A family member sharing the benefit of Amazon Prime Music will not work.
If you have never used the GPS on your watch, or if the battery has been completely discharged recently, you may be prompted to enable GPS after accessing the Amazon Music app. GPS can be enabled by choosing an outdoor activity. For details refer to your owner's manual.
The app will work in the following countries:
Australia
Austria
Brazil
Canada
Mexico
France
Germany
India
Italy
Japan
New Zealand
Spain
United Kingdom
United States
I Meet the Requirements. What Do I Do Next?
The three steps listed below need to be completed when first setting up the Amazon Music app with your watch. Once complete, you will only need to follow the third step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Connect IQ App for Amazon Music
A message should indicate that the app will be installed during the next sync. If this does not occur automatically, sync your watch manually:
To sync via Bluetooth: Be in range of your paired smartphone, and open the Garmin Connect app. Select on the My Day page to sync.
To sync via Wi-Fi: Be in range of your Wi-Fi network, and press the Menu button on the watch. Select Settings > Connectivity > Wi-Fi Sync and wait while the watch connects to Wi-Fi and syncs.
To sync using Garmin Express™ software: Connect the watch to a computer using the supplied power/data cable. Open the Garmin Express program. A sync will automatically occur once the watch is detected.
Once the sync is complete, the Amazon Music app will be installed onto your watch. When it installs, you can select the notification to begin the set up starting from step 7 within Step 2 below. If you dismiss the notification, proceed to the beginning of Step 2.
Step 2: Set up the Connect IQ App for Amazon Music
Once the app is installed, you will be prompted on the watch to continue setup.
Press Menu to access the menu.
Select Settings.
Select Music.
Select Music Providers.
Select Amazon Music.
The screen should prompt you to visit amazon.com/us/code. The code provided on the watch will tie it to your Amazon account. Use a mobile device or personal computer to complete this step. Once completed, allow up to a few minutes for the watch to proceed to the main menu.
You are ready to move to Step 3.
Step 3: Selecting and Syncing Content to the Watch
Your watch must connect to your Wi-Fi network to download content from Amazon Music.
Select Settings.
Select Music.
SelectAmazon Music.
Select Browse.
Choose a category then choose the content you want to sync to your watch.
At this point, the watch will attempt to connect to your Wi-Fi network. We recommend plugging the watch into an outlet near the Wi-Fi router for the best results.
After listening to your music, you can report all songs played to Amazon Music by selecting the Amazon Music icon from the Music Widget and then selecting Sync. You can also trigger a sync by plugging the watch in to charge.
