Reset the Vehicle Profile in the ecoRoute Feature
If you have set up a vehicle profile for use with the ecoRoute feature and would like to reset the data that was entered, follow these steps:
- Touch the Apps or Tools/Wrench icon from the main menu
- Touch ecoRoute
- Touch Vehicle Profile
- Touch the reset button on the bottom right-hand corner of the screen
- A message will ask if you would like to reset all data; select Yes
This will allow you to return to the initial setup of your Vehicle Profile.
Note: The first time you enter your vehicle settings, the new profile wizard appears. Follow the on-screen instructions.
- City Fuel Economy: Enter your city fuel economy.
- Highway Fuel Economy: Enter your highway fuel economy.
- Fuel Type: Select the type of fuel that your vehicle uses.
The available Fuel Types on ecoRoute are as follows:
- Unleaded: Fuel type that is used in most vehicles.
- Diesel: Used on any vehicle with a diesel engine.
- Ethanol: More commonly referred to as E85, or cars that can run 'Flex Fuel' can use this fuel.
- LPG: Liquefied Petroleum Gas, which is used in dual fuel models on select manufacturers and often used with fleet vehicles for efficiency purposes. Most cars have to be converted to run this type of fuel.
- CNG: Compressed Natural Gas, which is a fuel alternative that is used in trucks, buses, as well as trains. Along with LPG, CNG is a cleaner burning fuel that is designed to be more environmentally friendly.
