Auto Brightness on the Xero X1i Crossbow Scope
Auto Brightness is a featured located within the Pro Settings of the Xero® X1i Crossbow Scope. Auto Brightness works with an ambient light sensor in the scope that automatically adjusts display brightness as your environment changes around you. This setting will not change the color of your pin or ranged number.
Enable or Disable Auto Brightness
Auto Brightness automatically comes enabled on your device. To disable this feature, use the following steps.
  1. Select the gear icon.
  2. Select Pro Settings.
  3. Select Auto Brightness.
  4. Enable or disable Auto Brightness as desired.
Related
