Activate light boost feature on VIRB X/XE
The light boost setting on the Garmin VIRB X/XE enables automatic adjustment for low light.
To activate the light boost setting:
1. Power on device
2. Press and hold the Menu button
3. Select Video
4. Highlight Light Boost
5. Press OK to toggle on
This setting can only be activated when using the VIRB X/XE action camera in HD video mode. The Frames Per Second (fps) also needs to be set to 48 or 60.
To change video mode:
1. Press and hold the Menu button.
2. Select Video
3. Highlight Mode
4. Press OK to toggle through the video options
To change FPS (frames per second):
2. Select Video
3. Highlight FPS
4. Press OK to toggle between the options
Enabling the light boost setting on the VIRB X or VIRB XE should improve the video quality in low light situations.
