Using the Currency Converter on an Automotive Device
There may be times you will want to use the currency converter on your device. Below are the steps on how to use the currency converter.
To Use the Currency Converter on Your Device:
  1. Touch Apps or Tools
  2. Touch Unit Converter or Converter
  3. Touch the Conversion button, if currency is not already the unit being converted
  4. Touch Currency
  5. Touch OK or Save to save the change
  6. Touch a box with a currency listed
  7. Touch desired currency
  8. Touch OK to save the change
  9. Touch the field adjacent to or below the currency you would like to convert
  10. Enter the amount
  11. Touch Done or OK
The currency conversion will display automatically.
To make sure your device provides you with the most accurate and up-to-date currency conversions, you'll need to update the exchange rates.
To Update the Exchange Rates:
  1. Open the currency converter
  2. Set the converter to the two desired currencies
  3. Touch the button labeled with the pre-existing exchange rate
  4. Enter the current exchange rate for the currencies listed
  5. Touch OK or Done to save the change
The exchange rate for the currencies selected will now be set. To reset the exchange rate, or to set the exchange rate for other currencies, repeat the above steps.
