How Many Amps can Each Channel Use on the Garmin PowerSwitch?
The Garmin PowerSwitch™ cannot regulate the maximum amps directed to each channel. The Garmin PowerSwitch will provide up to 30 amps per channel and 100 amps max. The amps for each channel cannot be set manually. For example, you cannot direct one channel to put out only 15 amps.
NOTE: The readings visible on the Garmin PowerSwitch are merely for reference and shouldn't be used for any precision measurement.
