The Lily® and select vívosmart® and vívomove® watches have a timeout setting that allows you to set the length of time before the screen backlight turns off. A longer timeout will allow the backlight to stay on longer but will decrease battery life, while a shorter timeout will cause the backlight to stay on for a shorter amount of time but will increase battery life. Since these watches do not feature an always-on display option, changing your timeout settings can help you manage how long the screen stays visible.
For instructions on how to adjust this setting select your watch model below to reveal instructions.
Lily® Watches To adjust the timeout setting using your Garmin Connect™ account, select your preferred platform below.
Garmin Connect App Instructions Open the Garmin Connect app .
Access the menu by selecting More (bottom right).
Select Garmin Devices .
Select your Lily.
Select Appearance or System.
Select Display or Display Options .
Select General Use, During Activity, or During Sleep (Lily®2 Active only).
Select Timeout.
Select your preferred timeout length.
Back out of the settings to save your changes.
Sync your watch to apply the changes.
Garmin Connect Web Instructions NOTE: The steps below are not available for the Lily® 2 or Lily® 2 Active. Refer to the steps above using the Garmin Connect App.
Sign into Garmin Connect web from a personal computer.
Select Devices & Sync Status (top right).
Select your Lily.
Select Appearance .
Beneath Display Options , select your preferred Timeout length from the dropdown menu.
Select Save Settings .
vívomove® HR Watch To adjust the timeout setting from the watch see: vivomove HR Display Settings .
To adjust the timeout setting using Garmin Connect, select your preferred platform below.
Select your vivomove HR.
Select Device Settings .
Select Display Options .
Select Auto-On Display .
Garmin Connect Web Instructions Sign into Garmin Connect from a personal computer.
Select your vívomove HR.
Beneath Device Display , select your preferred Timeout length from the dropdown menu.
vívomove Watches These steps are for the: vívomove 3 | vívomove 3S | vívomove Style | vívomove Luxe | vívomove Sport
Select your vívomove watch.
Select Appearance .
Select your vivomove watch.
Select Appearance .
vívomove® Trend Watch Open the Garmin Connect app .
Select vivomove Trend.
Select Display .
Select Timeout .
Select: Short , Medium , or Long .
Sync your device. vívosmart® 3 Watch To adjust the timeout setting from the watch see: vivosmart 3 Display Settings .
Select your vívosmart 3.
Select Display Settings .
Select Auto-on Display .
Select your vivosmart 3.
vívosmart® 4 Watch The timeout setting can only be adjusted using Garmin Connect. Select your preferred platform below.
Select your vivosmart 4.
Select Appearance .
Select Appearance .
Select your preferred Timeout length from the dropdown menu.
