3D Terrain View
3D Terrain View displays map contours at low zoom levels, giving you a realistic perspective of the terrain in available areas. See an example of what 3D Terrain View looks like at the bottom of the article.
To Disable 3D Terrain View:
  1. Touch Settings
  2. Touch Map or Map Display
  3. Touch Map Layers
  4. Uncheck the box next to 3D Terrain
  5. Touch Save or OK
    • Skip this step on some devices
With the 3D Terrain map layer unchecked, the 3D Terrain mapping will be disabled. Place a check mark to re-enable the 3D Terrain mapping.
