The Elevation Reading on My Forerunner 945 LTE Is Wrong
The elevation reading you see comes from a barometric altimeter sensor inside the watch. This sensor detects barometric pressure changes in order to determine current elevation at a given point. If you believe the elevation reading from your watch is incorrect, review the following information to help troubleshoot and fix the problem.
Weather Changes Can Affect Sensor Accuracy
Weather can contribute to an incorrect reading. This includes:
  • An incoming or departing low or high-pressure system
    • This can cause your starting elevation reading to be too high or low. You should manually calibrate to a known elevation in this case. The elevation gain/loss during the recorded activity is typically not affected.
  • A windy day
    • Wind can affect the sensor causing an inaccurate reading. If you are going to record an activity outdoors when it is windy we suggest wearing the sleeve of a shirt or coat over the watch.
Clean the Sensor Port on the Watch
A blocked or clogged sensor port can lead to:
  • Wrong elevation or barometer readings
  • Incorrect Floors Climbed credit
To clean the sensor, locate the port on the back of the watch (it will be a small hole at the 6 o'clock position). You can rinse the port with water or you can also soak the watch in water for 5 minutes, agitating it every minute to help breakdown and remove any debris, such as sweat crystals or skin cells. After cleaning and/or soaking, allow the watch to dry completely.
IMPORTANT: Do not insert anything into openings on the watch (including canned air) as this can damage the internal sensor.
Calibrate the Sensor
With proper calibration the watch can achieve an accuracy of +/-50 feet at any given point. Use the information below to determine which calibration options are best for you.
Manually Calibrate the Sensor
  1. From the watch face hold the UP key to access the menu.
  2. Use the DOWN key to navigate to an select Sensors & Accessories.
  3. Select Altimeter.
  4. Select Calibrate.
  5. Select an Option:
    • Enter Manually (Enter current elevation?: Use this option to calibrate if you know the current elevation. This option offers the most accurate calibration.
    • Use DEM: The watch will locate your position through GPS and use the preloaded DEM (Digital Elevation Map) data to get an elevation reading for your current location.
    • Use GPS: This mode will determine your elevation through GPS triangulation. Elevation calibrated through GPS is accurate to +/-400 feet at any given point and is the least accurate.
Automatically Calibrate the Sensor
Make sure you are outside with a clear open view of the sky around you.
  1. Press and hold the UP button to enter the Main Menu.
  2. Press the down button 6 times and select Sensors & Accessories.
  4. Select Auto Cal.
    • During an Activity:
      • Continuous Mode: During activities the watch uses DEM mapping data and GPS elevation to offset any altimeter drift due to pressure changes caused by a weather event during an activity. Continuous Mode will allow the watch to calibrate altitude throughout the activity.
      • At Start: The watch will use DEM data and GPS location to calibrate the altimeter at the beginning of the activity. It will not calibrate again during the activity.
      • Off: The watch will not perform any calibration during or at the start of the activity.
    • Not During an Activity
      • ON: The watch will calibrate the altimeter anytime GPS is acquired by using DEM and your location.
      • OFF: The watch will not automatically calibrate the altimeter, and manual calibration will need to be used.
