Where to Cut
Cutting the Band Pin
The band pin will need to be cut to be removed. Cut the band pin using the wire cutter.
Garmin® watch band pins (or spring bars) are designed to work with our QuickFit® bands and to keep your watch band secured to the watch.
If you need replacement band pins they can be purchased on Garmin.com.
These new band pins are only compatible with the following watches:
Approach® S44
Approach® S50
Approach® S70 - 42 mm
Descent™ Mk2S
Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm
epix™ Pro (Gen 2) - Standard Edition - 42mm | epix™ Pro (Gen 2) - Sapphire Edition - 42mm
fēnix® 6S - Standard Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition 43 mm
WARNING! The band pin cannot be removed without cutting it. For this reason, Garmin recommends you take your watch to a jeweler or other professional to replace the band pin. Damage done to your watch while replacing the band pin may not be covered under Garmin's warranty.
The following items are needed to replace the band pin:
Your Garmin watch
A wire cutter
Replacement band pin(s)
Select an option below to reveal steps.
