Accessing the ecoRoute App
To use the ecoRoute app, an ecoRoute HD accessory cable must be paired to your automotive device. This accessory is no longer available to purchase from Garmin.
If you have the ecoRoute HD accessory cable, once the ecoRoute app has been activated on your device, it may be accessed through the Apps or Tools button on the main menu.
On compatible devices from the Camper/RV, dēzl™, and dēzlCam™ series, the ecoRoute app and the ecoRoute HD accessory cable will only work when the device is set to Automotive Mode.
