Creating or Selecting a Profile on the Montana 600 Series
Profiles are a great way to customize your Montana® 600 series handheld by allowing you to save different settings under each profile. This feature is helpful if you want to use your Montana handheld for multiple activities.
As an example with the Driving profile, you could have only street-routable maps enabled, change routing to Automobile Driving and have your map dashboard as Automotive.
Creating, Moving or Deleting a Profile
Preloaded profiles are: Recreational, Geocaching, Automotive, Marine, Fitness, Motorcycle and Classic. You can edit those profiles or create your own profile with the steps below.
- Touch
to reach the Main Menu
- Select Setup
- Select Profiles
- Select + Create New Profile to make your own. This profile will end up at the bottom of the profile list labeled with a number (i.e. Profile 10)
- You can also select any of the profiles listed if you wish to remove, edit or move them around in the list
Your changes should be saved.
Selecting a Profile
You can change profiles easily through the Main Menu.
- Touch
- Select Profile Change
- Select the desired profile
Your selected profile is now active.
