Garmin® Transducer Pin Connection and Considerations by Device
Garmin® manufacturers and has manufactured a variety of marine devices which support displaying image producing SONAR using either a built-in or an external SONAR module if compatible. External SONAR modules can in some cases be the built-in SONAR module of another compatible chartplotter. Some chartplotters models may require an external SONAR module, while others may be incompatible. All models require a compatible transducer with the appropriate pin layout to connect to the built-in or external SONAR module.
The actual transducer pin connection on the fishfinder, chartplotter or SONAR module varies. Older fishfinders, chartplotters and SONAR modules utilize our 6-pin connection. Newer model devices a feature 4-pin, 8-pin, 12-pin or a 21-pin connector. it is important to note that transducers and cables that connect directly up may or may not be compatible due to differences in internal wiring, internal hardware, or software.
It is necessary to insure the transducer is compatible with the fishfinder, chartplotter or SONAR module before connecting the transducer. For more information on current model transducer compatibility see the Transducer Selection Guide.
4 Pin Devices
      • echo™ 150 fishfinder
      • echo™ 300C fishfinder
      • echo™ 200 fishfinder
      • echo™ 151dv fishfinder
      • echo™ 201dv fishfinder
      • echo™ 301dv fishfinder
      • echo™ 551dv fishfinder
      • echo™ 101 fishfinder
      • echo™ 151 fishfinder
      • echo™ 201 fishfinder
      • echo™ 301c fishfinder
      • echo™ 501c fishfinder
      • echo™ 551c fishfinder
      • STRIKER™ 4 fishfinder
      • STRIKER™ 4cv fishfinder
      • STRIKER™ 5cv fishfinder
      • STRIKER™ 7cv fishfinder
      • STRIKER™ 7sv fishfinder
      • STRIKER™ Plus 4cv fishfinder
      • STRIKER™ Plus 5cv fishfinder
      • STRIKER™ Plus 7cv fishfinder
      • STRIKER™ Plus 9sv fishfinder
      • STRIKER™ Vivid 4 fishfinder
      • STRIKER™ Vivid 5 fishfinder
      • STRIKER™ Vivid 7 fishfinder
      • STRIKER™ Vivid 9 fishfinder
      • echoMAP™ 42dv combination chartplotter and sounder
      • echoMAP™ 43dv combination chartplotter and sounder
      • echoMAP™ 44dv combination chartplotter and sounder
      • echoMAP™ 53dv combination chartplotter and sounder
      • echoMAP™ 53cv combination chartplotter and sounder
      • echoMAP™ 54dv combination chartplotter and sounder
      • echoMAP™ 73dv combination chartplotter and sounder
      • echoMAP™ 73sv combination chartplotter and sounder
      • echoMAP™ 74dv combination chartplotter and sounder
      • echoMAP™ 74sv combination chartplotter and sounder
      • echoMAP™ 93sv combination chartplotter and sounder
      • echoMAP™ 94sv combination chartplotter and sounder
      • echoMAP™ CHIRP 42cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 42dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 43dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 43cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 44dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 44cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 45dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 45cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 52dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 52cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 53dv chartplotter and sounder combo with CHIRP sonar
      • echoMA™ P CHIRP 53cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 54dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 54cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 55dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 55cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 42cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 43cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 44cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 45cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 62cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 63cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 64cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ Plus 65cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD 62cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD 63cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD 64cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD 65cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD2 53cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD2 72cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD2 73cv chartplotter and sounder combo with sonar technology
      • ECHOMAP™ UHD2 74cv chartplotter and sounder combo with sonar technology
6 Pin Devices
      • GSD™ 20 sonar module
      • GSD™ 21 sonar module
      • GSD™ 22 sonar module
      • GPSMAP® 420s chartplotter and sonar combo
      • GPSMAP® 430s chartplotter and sonar combo
      • GPSMAP® 440s chartplotter and sonar combo
      • GPSMAP® 421s chartplotter and sonar combo
      • GPSMAP® 431s chartplotter and sonar combo
      • GPSMAP® 441s chartplotter and sonar combo
      • GPSMAP® 520s chartplotter and sonar combo
      • GPSMAP® 530s chartplotter and sonar combo
      • GPSMAP® 540s chartplotter and sonar combo
      • GPSMAP® 525s chartplotter and sonar combo
      • GPSMAP® 535s chartplotter and sonar combo
      • GPSMAP® 545s chartplotter and sonar combo
      • GPSMAP® 526s chartplotter and sonar combo
      • GPSMAP® 536s chartplotter and sonar combo
      • GPSMAP® 546s chartplotter and sonar combo
      • GPSMAP® 720s chartplotter and sonar combo
      • GPSMAP® 740s chartplotter and sonar combo
      • GPSMAP® 178 chartplotter and sonar combo
      • GPSMAP® 178c chartplotter and sonar combo
      • GPSMAP® 188 chartplotter and sonar combo
      • GPSMAP® 188c chartplotter and sonar combo
      • GPSMAP®   198c chartplotter and sonar combo
      • GPSMAP® 238 chartplotter and sonar combo
      • GPSMAP® 135 chartplotter and sonar combo
      • GPSMAP® 185 chartplotter and sonar combo
      • GPSMAP® 235 chartplotter and sonar combo
      • GPSMAP® 298 chartplotter and sonar combo
      • GPSMAP® 398 chartplotter and sonar combo
      • GPSMAP® 498 chartplotter and sonar combo
      • GPSMAP® 168 chartplotter and sonar combo
      • Fishfinder 160
      • Fishfinder 240
      • Fishfinder 100
      • Fishfinder 100 Blue
      • Fishfinder 160 Blue
      • Fishfinder 240 Blue
      • Fishfinder 320C
      • Fishfinder 80
      • Fishfinder 120
      • Fishfinder 250C
      • Fishfinder 250
      • Fishfinder 160C
      • Fishfinder 90
      • Fishfinder 140
      • Fishfinder 340C
      • Fishfinder 300C
8 Pin Devices
      • GSD™ 24 advanced sonar module
      • GSD™ 25 premium sonar module
      • echoMAP™ 50s combination chartplotter and sounder
      • echoMAP™ 50dv combination chartplotter and sounder
      • echoMAP™ 70s combination chartplotter and sounder
      • echoMAP™ 70dv combination chartplotter and sounder
      • echoMAP™ CHIRP 72dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 72cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 73dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 73cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 74dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 74cv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 75dv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 75cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 72cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 73cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 74cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 75cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ UHD 72cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ UHD 73cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ UHD 74cv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ UHD 75cv chartplotter and sounder combo with CHIRP sonar
      • *GPSMAP® 527xs chartplotter and sonar combo
      • *GPSMAP® 547xs chartplotter and sonar combo
      • *GPSMAP® 721xs chartplotter and sonar combo
      • *GPSMAP®   741xs chartplotter and sonar combo
      • GPSMAP® 820xs chartplotter and sonar combo
      • GPSMAP® 840xs chartplotter and sonar combo
      • GPSMAP® 1020xs chartplotter and sonar combo
      • GPSMAP® 1040xs chartplotter and sonar combo
      • GPSMAP® 722xs chartplotter and sonar combo
      • GPSMAP® 742xs chartplotter and sonar combo
      • GPSMAP® 922xs chartplotter and sonar combo
      • GPSMAP® 942xs chartplotter and sonar combo
      • GPSMAP® 722xs Plus chartplotter and sonar combo
      • GPSMAP® 742xs Plus chartplotter and sonar combo
      • GPSMAP® 922xs Plus chartplotter and sonar combo
      • GPSMAP® 942xs Plus chartplotter and sonar combo
      • GPSMAP® 7407xsv chartplotter and sonar combo
      • GPSMAP® 7607xsv chartplotter and sonar combo
      • GPSMAP® 7408xsv chartplotter and sonar combo
      • GPSMAP® 7608xsv chartplotter and sonar combo
      • GPSMAP® 7410xsv chartplotter and sonar combo
      • GPSMAP® 7610xsv chartplotter and sonar combo
      • GPSMAP® 7412xsv chartplotter and sonar combo
      • GPSMAP® 7612xsv chartplotter and sonar combo
      • GPSMAP® 7416xsv chartplotter and sonar combo
      • GPSMAP® 7616xsv chartplotter and sonar combo
      • GPSMAP® 8410xsv chartplotter and sonar combo
      • GPSMAP® 8610xsv chartplotter and sonar combo
      • GPSMAP® 8412xsv chartplotter and sonar combo
      • GPSMAP® 8612xsv chartplotter and sonar combo
      • GPSMAP® 8416xsv chartplotter and sonar combo
      • GPSMAP® 8616xsv chartplotter and sonar combo
*Some models were equipped with both an 8-pin and a 12-pin SONAR port, if an error message appears, see the Related Content section below.
12 Pin Devices
      • GSD™ 25 advanced sonar module
      • GCV™ 10 scanning sonar module
      • GCV™ 20 scanning sonar module
      • echoMAP™ CHIRP 72sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 73sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 74sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 92sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 93sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 94sv chartplotter and sounder combo with CHIRP sonar
      • echoMAP™ CHIRP 95sv chartplotter and sounder combo with CHIRP sonar
      • ECHOMAP™ Plus 72sv combination chartplotter and sounder
      • ECHOMAP™ Plus 73sv combination chartplotter and sounder
      • ECHOMAP™ Plus 74sv combination chartplotter and sounder
      • ECHOMAP™ Plus 75sv combination chartplotter and sounder
      • ECHOMAP™ Plus 92sv combination chartplotter and sounder
      • ECHOMAP™ Plus 93sv combination chartplotter and sounder
      • ECHOMAP™ Plus 94sv combination chartplotter and sounder
      • ECHOMAP™ Plus 95sv combination chartplotter and sounder
      • ECHOMAP™ UHD 72sv combination chartplotter and sounder
      • ECHOMAP™ UHD 73sv combination chartplotter and sounder
      • ECHOMAP™ UHD 74sv combination chartplotter and sounder
      • ECHOMAP™ UHD 75sv combination chartplotter and sounder
      • ECHOMAP™ UHD 92sv combination chartplotter and sounder
      • ECHOMAP™ UHD 93sv combination chartplotter and sounder
      • ECHOMAP™ UHD 94sv combination chartplotter and sounder
      • ECHOMAP™ UHD 95sv combination chartplotter and sounder
      • ECHOMAP™ UHD2 64sv combination chartplotter and sounder
      • ECHOMAP™ UHD2 73sv combination chartplotter and sounder
      • ECHOMAP™ UHD2 74sv combination chartplotter and sounder
      • ECHOMAP™ UHD2 93sv combination chartplotter and sounder
      • ECHOMAP™ UHD2 94sv combination chartplotter and sounder
      • ¹ECHOMAP™ Ultra 102sv combination chartplotter and sounder
      • ¹ECHOMAP™ Ultra 106sv combination chartplotter and sounder
      • ¹ECHOMAP™ Ultra 122sv combination chartplotter and sounder
      • ¹ECHOMAP™ Ultra 126sv combination chartplotter and sounder
      • ECHOMAP™ Ultra 2 102sv combination chartplotter and sounder
      • ECHOMAP™ Ultra 2 106sv combination chartplotter and sounder
      • ECHOMAP™ Ultra 2 122sv combination chartplotter and sounder
      • ECHOMAP™ Ultra 2 126sv combination chartplotter and sounder
      • ¹GPSMAP® 527xs chartplotter and sonar combo
      • ¹GPSMAP® 547xs chartplotter and sonar combo
      • ¹GPSMAP® 721xs chartplotter and sonar combo
      • ¹GPSMAP®   741xs chartplotter and sonar combo
      • GPSMAP® 723xsv chartplotter and sonar combo
      • GPSMAP® 743xsv chartplotter and sonar combo
      • GPSMAP® 923xsv chartplotter and sonar combo
      • GPSMAP® 943xsv chartplotter and sonar combo
      • GPSMAP® 1022xsv chartplotter and sonar combo
      • GPSMAP® 1042xsv chartplotter and sonar combo
      • GPSMAP® 1222xsv chartplotter and sonar combo
      • GPSMAP® 1242xsv chartplotter and sonar combo
      • GPSMAP® 1222xsv Touch chartplotter and sonar combo
      • GPSMAP® 1242xsv Touch chartplotter and sonar combo
      • GPSMAP® 1222xsv Plus chartplotter and sonar combo
      • GPSMAP® 1242xsv Plus chartplotter and sonar combo
      • GPSMAP® 1223xsv chartplotter and sonar combo
      • GPSMAP® 1243xsv chartplotter and sonar combo
      • GPSMAP® 1623xsv chartplotter and sonar combo
      • GPSMAP® 1643xsv chartplotter and sonar combo
      • ²GPSMAP® 8410xsv chartplotter and sonar combo
      • ²GPSMAP® 8610xsv chartplotter and sonar combo
      • ²GPSMAP® 8412xsv chartplotter and sonar combo
      • ²GPSMAP® 8612xsv chartplotter and sonar combo
      • ²GPSMAP® 8416xsv chartplotter and sonar combo
      • ²GPSMAP® 8616xsv chartplotter and sonar combo
¹Change in production occurred and some models were equipped with both an 8-pin and a 12-pin SONAR port, if an error message appears, see the Related Content section below.
²The LVS XDCR port is also a 12-pin SONAR port. The 12-pin LVS XDCR port is exclusively for the discontinued LVS 12 LiveScope™ real-time sonar and features a completely different pin configuration. GPSMAP® chartplotter and sonar combo units feature 3 SONAR ports (8-pin, 12-pin XDCR & a 12-pin LVS XDCR. ECHOMAP™ combination chartplotter and sounder units feature 2 SONAR ports (12-pin XDCF & a 12-pin LVS XDCR. Pin information and wiring is not available for the LVS 12 transducer. The LVS 12 transducer is not compatible with the 21-pin GLS™ 10 sonar module . Transducers with a 21-pin connector must be connected to a GLS™ 10 sonar module and for compatibility see Garmin Sonar Module Compatibility.
NOTE: Water speed is not a feature available on 12-pin SONAR ports. For more information on this see Garmin Chartplotter with 12-Pin Sonar Port Compatibility with Triducers.
21 Pin Device
    • GLS™ 10 Sonar Module
Pin information and wiring is not available for transducers that connect to the GLS™ 10 sonar module. The LVS 12 transducer is not compatible with the GLS™ 10 sonar module .
In some cases a compatible transducer may require an adapter cable or an 8-pin or a 12-pin wire block adapter. For more information on which adapter cable to buy, see Buying Parts or Accessories Directly from Garmin.
Some transducers that are bundled with a fishfinder or chartplotter may include an adapter. The transducer included may need to be adapted up or down depending on which SONAR port is required, and compatibility needs to be verified. These transducers are not necessarily for exclusive use with the included unit and may work with other fishfinders, chartplotters, and SONAR modules.
The GSD™ 26 sonar module and GSD™ 28 sonar module which is not listed above is a bare wire solution that supports bare wire transducers as well as 4-pin, 6-pin and 8-pin transducers with additional programming and other considerations. For more information on this see the following FAQs:
  • Wiring Diagrams for Airmar Transducers Compatible with the Garmin GSD 26
    NOTE: If wiring a 4-pin, 6-pin or 8-pin transducer in to a GSD 26, the following referenced FAQs will have the correct wiring diagrams
    NOTE: Cutting a Garmin Transducer Cable is not recommend of the actual transducer when there is a connector, but using a bare wire solution to make the connection will be required with a GSD™ 26, and a solution is offered in the referenced FAQ in this note
  • The Garmin GSD 24 Compatible Transducers Wiring Diagram FAQ provides additional wiring diagrams for 8-pin transducers which can also be connected up to a GSD™ 26 sonar module or GSD™ 28 sonar module factoring in the above note
    • For the GSD™ 26 sonar module, manual configuration may be necessary, for more information see or
    • For the GSD™ 28 sonar module, manual configuration may be necessary, for more information see the Installation Instructions
Related
