Pairing Handset to Cortex™ M1 Hub With Software Earlier Than 1.5
When pairing earlier version handsets (prior to 1.5) to the Cortex™ M1Hub, the menus are very different than later versions.
Follow the steps below to pair the handset to the pod, so that the handset can be updated to the latest version software.
To pair the handset to the hub, go to main menu > tap the Configuration option (wrench) > Networks > Wi-Fi.
Networks Config
This will open a view that shows Hub, SSID CORTEX- 00000000. Tap on this SSID.
Configuration
The Wi-Fi SSID of the device will be displayed.
CORTEX SSID
Tap on the SSID that is on the device. The QR code will have this information. as well as the WPA password.
 Cortex WPA Password
Tap the space above the line and the the keyboard will appear. IT IS CASE SENSITIVE.
Tap connect to connect to the hub.
Cortex Connecting
Once connected there will be instructions on the handset to update the handset to the latest firmware that is on the Hub, M1. Follow these instructions and update the handset .
At which time the handset will restart, and will have the M1 version. Be sure to keep the Cortex® updated with the latest firmware to enjoy the many benefits and new features that are being rolled out, regularly.
Related
