Pairing a Dog Tracking Collar to the Pro 550 Plus
The Pro 550 Plus dog tracking handheld can track three collars at one time.
Pairing
Pairing a compatible collar to a Pro 550 Plus handheld
  1. Power on the handheld
  2. Select a color with the Toggle switch
    NOTE: The dog collar will be assigned to this color
  3. Turn the intensity dial to N
  4. Select the green Tone key
  5. With Pair Collar highlighted, select the green Tone key again
  6. Follow the on-screen instructions to select auto, tree, or point for the type of dog wearing the collar appears on the handheld device screen.
    NOTE: You can cancel pairing by pressing the green tone key.
  7. If the dog collar device is on, turn it off (not required for T 5X, TT™ 15X, Alpha T20, and Alpha TT25 collars)
  8. Hold the Power key on the dog collar until it emits two series of beeps (about 5 seconds), and then release the Power key. The status LED will flash green rapidly
The handheld vibrates and a checkmark appears on the screen when the devices have paired successfully.
