Verifying Maps Installed on an Automotive Device
Note: If the steps/instructions below do not work for your device, click on Support Center and enter the Product Name or the Serial Number of your device. Once your device is entered, select Search Other Topics and
For Automotive Devices: search for "Check Maps Installed".
For Fitness Devices: search for "Check Maps Installed".
For Outdoor Devices: search for "Check Maps Installed".
For Marine Devices: see Marine Cartography Error Report.
If your device displays the error "No matches found" or "Cannot Find Search Results" after a map update, this may indicate that the full maps were not installed to the device. Check the device's mapping to confirm this.
To Check the Mapping:
1. Touch Settings
2. Touch Map & Vehicle
3. Arrow down and Touch myMaps or Configure Maps
Make note of the name of the map region, which is listed next to the map version.
Devices loaded with North America mapping will have the map displayed as two separate entries:
- CN North America ALL Canada and Mexico
- CN North America ALL US
See the FAQ North America Map Coverage for more information.
If your device does not have both of the above entries, you may need to update the device using a memory card. If issues persist, see the FAQ Maps Missing After Updating Maps on a Full Coverage Automotive Device for further troubleshooting steps.
