Pairing the inReach Messenger for the inReach Remote Widget
Some Garmin products have the ability to pair with the inReach® Messenger device and use some of the inReach® satellite communication features that it offers.
Even though both devices need to be in close proximity (10ft) to each other, it can be helpful to strap your inReach Messenger device on your pack or person, and then use a smaller non-inReach device for messaging, SOS, etc.
This article walks you through the process of getting these devices paired together.
Enabling the inReach Remote Mode on the inReach Messenger
NOTE: These steps are not applicable when connecting to the Overlander® GPS navigator. If you intend to use your inReach Messenger with the Overlander GPS navigator, see - Pairing an inReach to an Overlander GPS navigator.
From the home page, press or to scroll through the main menu options.
Select Settings .
Select inReach Remote.
Select Status to set the inReach Remote function to On.
Choose a Verification option:
On: Allows pairing only to approved inReach Remote devices.
Off: Allows pairing to any nearby inReach Remote devices without approval.
With the inReach Remote sensor enabled, the inReach Messenger is ready to pair with a compatible device.
Enabling and Connecting the inReach Remote Widget
Last, you need to pair your compatible non-inReach device. Steps will vary by the type of device you are using.
Garmin Watches
TIP: If you have previously used another inReach device with the watch and wish to remove it, this can be done by selecting it in the Sensors & Accessories menu of the watch. For detailed steps, see - Removing Sensors From Watches.
Hold UP/MENU.
Select or scroll to Settings.
Select Sensors & Accessories.
Select Add New.
Select inReach.
The watch will begin searching for and connecting to the inReach device. This can take up to 60 seconds.
Select inReach - (device number) once it appears on the watch.
Once connected, the inReach Remote widget should be enabled automatically. If it is not, refer to "Customizing the Widget/Glance Loop" in your watch's owner's manual for instructions to add it.
From the watch face, scroll to the inReach Remote widget to see your messages. While viewing the inReach Remote widget, select START/STOP to access the menu for SOS, Messages, or Tracking.
Edge® Cycling Computers
For steps to enable the inReach Remote widget on a compatible Edge cycling computer, refer to the device owner's manual below.
These are general instructions that should work with most compatible chartplotters. For more detailed instructions, refer to your chartplotter's owner's manual.
On the chartplotter, select A/V.
NOTE: If you do not see A/V, select OneHelm first.
Select Gauges.
Select inReach.
Select Start Pairing.
The chartplotter will begin searching for and connecting to the inReach device. This can take up to 60 seconds.
If necessary, compare the code on the inReach device to the chartplotter, and select OK if they match.
Automotive Devices
For steps to enable the inReach Remote widget on a compatible automotive device, refer to the articles below:
