Using Suggested Stops on a dēzl™ Device
Note: The Suggested Stops feature is not an approved substitute for logbook recording requirements under Federal Motor Carrier Safety Administration (FMCSA) regulations. A Garmin eLog™ compliant Electronic Logging Device (ELD), when integrated with your dēzl™ device, will allow a motor carrier to comply with Hours of Service (HOS) logging and break requirements. For more information, visit garmin.com/eLog.
If you have approached the maximum number of drive hours on your route, Suggested Stops will notify you and suggest adding a stop to the route to prevent an HOS violation.
To use this feature, your device must be in the Truck usage mode. For steps to change the usage mode, see Related Content.
To Enable the Suggested Stops Feature:
  1. Touch Settings
  2. Touch Navigation
  3. Touch the check box next to Suggested Stops
The Suggested Stops feature will now be enabled on your device. If prompted, use the Hours of Service app to create a driver profile.
When Prompted that an Hours of Service (HOS) Stop is Required, use the Following Directions to Add a Stop:
  1. Touch the alert bar at the top of the screen
  2. Touch Add Stop
  3. Select the stop you would like to add
This will add a stop to the route to prevent an HOS violation.
Related
