Setting a Collection to Sync Using the Garmin Explore Website
The Garmin Explore™ website can be used to set certain collections to sync to specific devices in your Garmin Explore account.
A Collection can be set to sync to a device either through the Plans & Devices page or the Map page in the Garmin Explore website.
For information on creating, editing, and deleting collections using the Garmin Explore website, see -  Managing Collections on the Garmin Explore Website Map Page.
Setting a Collection to Sync Using the Plans & Devices Page
Individual collections can be selected to sync from the Garmin Explore website to a specific device. The steps below show you how to do this using the Plans & Devices page in your Garmin Explore account.
  1. Log in to the Garmin Explore website.
  2. Select PLANS & DEVICES.
  3. Select Collections next to the desired device.
    Garmin Explore Website Select Collections
  4. Select Sync Selection.
    Garmin Explore Website Select Sync Selection
    NOTE: The option to choose individual collections to sync is only available if the Sync Selection option is chosen. If the Sync Everything option is chosen, then the entire library will be set to sync.
  5. Select the drop down under Primary Collection.
    Gamin Explore Website Select Primary Collection
  6. Select a primary collection.
    Garmin Explore Website Primary Collection Selected
    NOTE: Data in the primary collection is automatically set to sync to the device.
  7. Select additional collections to sync.
    NOTE: If you get the Collection Size Warning message, select Save to continue.
    Garmin Explore Website Select Additional Collections
NOTE: Collections containing over 100 waypoints, 20 routes, 5 tracks, or a track with over 10,000 points may be too large to sync with your device and are marked with a yellow warning icon.
The selected collections are now set to sync to the device. Perform a sync with your device for it to have these updates:
NOTE: If the selected collection data does not show after syncing a Garmin Explore app compatible device, follow the steps in Setting a Collection to Sync Using the Garmin Explore App to ensure the collection is toggled on to sync in the app.
Setting a Collection to Sync Using the Map Page
Individual collections can be selected to sync from the Garmin Explore website to a specific device. The steps below show you how to do this using the Map page in your Garmin Explore account.
  2. Select Map.
  3. Select a Collection in the left side panel.
    Garmin Explore Website Select a Collection
    NOTE: If the left side panel is not visible, select Garmin Explore Website Open Library to open it.
  4. Select Garmin Explore Website Sync Icon.
  5. Select the desired collections to sync.
  6. Select Save.
Related
