Select Radio from the Main Menu.
Select
Select Setup Radio.
Select Squelch Tone Mode.
Select CTCSS.
The Rino 600 series will now start receiving and transmitting messages to older Rino handhelds.
If an older generation Rino® handheld will not communicate with a Rino 610, 650, 650t, 655t, 700, 750, 750t, or 755t handheld, it is likely the Squelch Tone Mode is set to DSC. Once the setting is changed to CTCSS, the Rino 600/700 series handheld will be able to communicate with the older Rino handhelds. Older generation Rino handhelds include:
Rino 110, 120, 130
NOTE: While the Rino 100 series and Rino 600/700 series devices allow radio communication, they do not keep a stable connection for the location or contact features.
Rino 520 and 530
Rino 520HCx and 530HCx
Select .
Select Setup Radio.
Select CTCSS.
From the main menu, use the thumb stick to select Radio.
Press .
Select Setup Radio.
Select CTCSS.
The Rino 700 will now start receiving and transmitting messages to older Rino handhelds.
From the main menu, swipe up from the bottom of the screen to access the App Drawer.
Select Radio.
Select .
Select Radio Setup.
Select CTCSS.
The Rino 750, 750t, or 755t will now start receiving and transmitting messages to older Rino handhelds.
When setting up or testing communication between Rino radios, it is recommended to keep the devices a minimum of 10 feet apart when transmitting.
