Formatting a USB Drive for an Acura NSX Navigation System
A USB drive may require formatting before it can be used with an Acura NSX navigation system. Follow the instructions at https://acura.garmin.com/acura/ before formatting. Format the USB flash drive and try again if an issue is experienced during the update.
Note: A 16GB USB flash drive is required for the the Acura NSX Navigation System update. Using a USB flash drive smaller or larger than 16GB can cause the map update process to be unsuccessful.  See the vehicle's Owner's Manual to verify if a 2.0 or 3.0 USB flash drive can be used.
To Format the USB Drive:
Windows
1. Insert the USB drive into the computer
2. Press the Windows key + E
3. Click This PC (Windows 10 only)
4. Locate the drive representing the USB drive
5. Right-Click on the USB drive
6. Click Format
7. Verify the File System is FAT or FAT32
8. Change Allocation unit size to Default allocation size
9. Ensure Quick Format is checked
10. Click Start
These steps will format the USB drive to be readable by the Acura NSX navigation system.
Try another 16GB USB flash drive if an error is received or formatting the USB drive fails to resolve the issue.
Mac
2. Open Spotlight (CMD + Space) on the keyboard
3. Type Disk Utility into the Spotlight search box
4. Press Return
5. Click the parent icon for the USB drive in the sidebar on the left
  • This is not necessary on Mac OS X 10.12 and newer.
  • To determine which drive is the USB drive:
    • Remove the USB drive from the computer.
    • Observe which drive disappears from the list.
    • Insert the USB drive again.
  • See Acura NSX Map Update USB Not Detected by Garmin Express on a Mac if the computer does not recognize the USB drive.
6. Click Erase at the top of Disk Utility
7. Select MS-DOS (FAT) in the Format drop-down menu
red box around MS-DOS (FAT)
8. Type a name/title for the USB drive
  • Do not leave the name as "UNTITLED" or "NO NAME"
red box around word garmin
9. Click Erase
Try another USB flash drive if an error is received or formatting the USB drive fails to resolve the issue.
