Changing the Vehicle Type/Usage Mode on a dezl
Your Device can use the Following Usage Modes to Calculate Routes:
Straight Truck or Tractor: This setting will provide turn-by-turn directions using major roads that will allow large vehicles such as Semi Trucks.
Car: This setting provides turn-by-turn directions based on mapping and road information.
It will ignore limitations such as weight restrictions or low bridge clearances.
Bus: This setting will provide turn-by-turn directions similar to truck mode.
It will use bus speed limits, when available, and roads buses are not allowed on. Some roads will allow buses but not trucks, or trucks but not buses. It is important to select the Bus Profile and not the Truck Profile when used on a bus to take these factors into consideration.
These Videos are a Quick and Easy way to Learn About the Vehicle Profiles:
dēzl™ LGV500, dēzl™ OTR500, dēzl™ LGV700, and dēzl™ OTR700
dēzl™ LGV610, dēzl™ OTR610, dēzl™ LGV710, and dēzl™ OTR710
dēzl™ LGV620, dēzl™ OTR620, dēzl™ LGV720, and dēzl™ OTR720
dēzl™ LGV820, dēzl™ OTR820, dēzl™ LGV1020, and dēzl™ OTR1020
dēzlCam™ LGV710 and dēzlCam™ OTR710
dēzlCam™ LGV725 and dēzlCam™ OTR725
To Change the Vehicle Type:
1. Touch the vehicle profile icon from the status bar
2. Select a vehicle type or touch the plus icon for more options
3. If the plus icon was selected, the vehicle can be selected here
Repeat the steps above to change the vehicle type again.
