Creating an ActiveCaptain Card
To use the ActiveCaptain App, it must have an ActiveCaptain card inserted into the chartplotter. The data card is either a micro/SD card up to 1TB* depending on the model of chartplotter; micro/SD cards are purchased locally at any electronics retailer.
  • A reused micro/SD card is acceptable but needs to be formatted to clear data from the card
  • Do not use a preloaded chart card; use a separate micro/SD card for the ActiveCaptain App. A different micro/SD card prevents accidental erasure of the preloaded chart card
Card Classes
 UHS 3UHS3 Class Card Best
 UHS 1 UHS1 Class CardGood
 Class 10 Class10 Class CardGood
 Class 6 Class 6 CardOK
 Class 4 Class 4 CardSlow
 Class 2 Class 2 CardSlowest
To create the ActiveCaptain card, insert the card into the chartplotter. A GPSMAP unit will create an ActiveCaptain card either powered on or powered off. An ECHOMAP unit will need to follow directions listed in the dropdown below titled ActiveCaptain Card Starting with the Chartplotter Powered ON. Instructions are below for both methods.
* Not all devices will be compatible with the new exFAT file system. Refer to New exFAT support on Garmin Marine Devices
Creating the ActiveCaptain Card Starting with the Chartplotter Powered ON:
Insert the micro/SD card (depends on model) into the chartplotter while powered on.
Most chartplotters have two card slots; either card slot is acceptable.
Select the option Set ActiveCaptain Card
Memory Card slot - no preloaded map
Select Skip. If the card is new or has a preloaded chart, select  Skip.
Once the ActiveCaptain card is created, it should remain in the unit to use the ActiveCaptain app.
Skip or format options shown on chartplotter screen
When reusing a card that contains data not needed for the chartplotter, select Format Card, and all the data on the card is erased. Do not use  Format Card if the card contains a preloaded chart.
Select Skip; if the card is new or has a preloaded chart, select the Skip.
 The ActiveCaptain card should remain in the unit to use the ActiveCaptain app.
format or skip options shown on chartplotter
Creating the ActiveCaptain Card from a Powered off Chartplotter:
When the card is being reused and contains data not needed for the chartplotter, select Format Card to erase all the card data. Do not use the Format Card if the card contains a preloaded chart.
Select Skip; if the card is new or has a preloaded chart, select  Skip.
memory card ActiveCaptain options on chartplotter
Related
