An Amazon Music Unlimited subscription is required for a fully customized experience. While having just an Amazon Prime subscription will work, it will be limited to Amazon curated playlists as well as songs you have purchased. For more details see the following Amazon FAQ: What are the Differences Between the Amazon Music Subscriptions?
You must be the Amazon Prime primary account holder. A family member sharing the benefit of Amazon Prime Music will not work.
If you have never used the GPS on your watch, or if the battery has been completely discharged recently, you may be prompted to enable GPS after accessing the Amazon Music app. GPS can be enabled by choosing an outdoor activity. For instructions see: Going for a run.
The app will work in the following countries:
Australia
Austria
Brazil
Canada
France
Germany
India
Italy
Japan
Mexico
New Zealand
Spain
United Kingdom
United States
I Meet the Requirements. What's Next?
The steps listed below need to be completed when first setting up the Amazon Music app with your Venu series or Venu Sq - Music Edition watch. Once complete, you will only need to follow the last step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Amazon Music Connect IQ App
The message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your device:
To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the top right button to access the Controls Menu. Select to sync.
To sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the top right button to access the Controls Menu. Select to sync.
To sync using Garmin Express: Connect the device using supplied power/data cable to a computer. Open Garmin Express. A sync will automatically occur once the device is detected.
Once the sync is complete, the Amazon Music app will be installed on your device.
Step 2: Set Up the Amazon Music Connect IQ App on the Watch
Once the app is installed, you will be prompted on the watch to continue the setup process.
Press and hold the bottom button.
Select or Settings.
Select Music.
Select Music Providers.
Select Amazon Music.
The screen should prompt you to visit https://amazon.com/code on a mobile device or personal computer.
The code provided on the watch will tie it to your Amazon account.
Once completed allow up to a few minutes for the watch to proceed to the main menu.
Select a category then choose the content you want to sync to your watch.
The watch will attempt to connect to your Wi-Fi network.
We recommend plugging the watch into a charger near the Wi-Fi router for the best results.
After you have added content to your watch, any changes you make to your playlist(s) will sync over automatically when your watch is charging and in the range of a saved Wi-Fi network.
You can also manually initiate a sync to update playlists and report all songs played to Amazon Music by following these steps:
Select or Settings.
Select Music.
Select Sync.
