Fusion® MS-AV755 Manual Software Update
Fusion® MS-AV755 software version 1.21.41
as of October 18, 2018
Download (11.87 MB)
View installation instructions and system requirements
Notes:
- This firmware release also contains updates for DAB+ accessories and NRX remote controls.
- NRX Series Remote 1.02.75
- DAB+ Module STM32 1.01
- DAB+ Tuner 4.05
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the 'update' menu in the 'settings' menu to be compatible with your Fusion Entertainment System
- Please note this software does not work on the MS-AV750 or MS-UD750. If you require the software for either of these products, please manually search for it within the legacy section of our website.
Change History
Changes made from version to 1.21:
- General bug fixes and improvements
- HDMI compatibility with new TV issue resolved
- USB long track issue resolved
- Updated remote version
- Updated DAB version
Installation Instructions
- Insert a blank USB flash drive formatted in FAT32 with a capacity of at least 4gb and no larger than 32gb into the PC/laptop
- Download the FusionMS-AV755 update file to the PC/laptop and open it
- Drag the Update folder onto the USB flash drive
- The Update folder should now be the only folder on the USB flash drive
- Connect the USB flash drive to the USB Port of the stereo
- On the stereo, select Menu > Settings > Update > Update Software
- The DAB+ module and remotes can now be updated from the update menu if required
System requirements
- IBM-compatible PC running Windows 2000 or later operating system and an available USB port.
