Select Contacts.
Select New Contact.
Select Email Address, SMS Number, or inReach Address.
Use the keypad to enter the contact details, select OK.
NOTE: Phone numbers needs to be in the following format (minus the brackets): +[Country Code][SMS number]. For more information on country codes, see - https://countrycode.org/
Enter additional information about the contact, then press the X button when done.
Managing Contacts in an inReach SE or inReach Explorer
The inReach SE® and inReach Explorer® handhelds are capable of storing phone numbers, email addresses, and inReach® addresses to use as contacts. Use the instructions below to either add contacts to or delete contacts from the inReach handheld.
Select Contacts.
Highlight the contact to delete, and press the Check button.
Select Delete.
Select Delete to confirm.
