Quick Text messages are helpful to save time not having to type out commonly-used phrases and replies. These messages must be updated on the Garmin Explore™ website, in the Garmin Messenger™ app, or in the Earthmate® app before heading out on a trip and cannot be edited on the inReach® device itself.
Use the instructions below for the website or a compatible app to add, edit, or delete Quick Text messages from an inReach account.
+ Expand all
Creating and Editing Quick Text Messages Using the Garmin Explore WebsiteIMPORTANT: Be sure to log into the account the inReach device is assigned to. After making changes within a Garmin Explore™ website account, make sure to sync the device and app so they reflect the changes. See Related for instructional links on how to sync.
Adding Quick Text MessagesLog in to the Garmin Explore website .
Select MESSAGES .
NOTE: On mobile browsers, select in the top left, then MESSAGES .
Select Add, located at the bottom of the list of Quick Text messages.
Enter the text of your Quick Text message.
There is a limit of 20 Quick Text messages and each message is limited to 160 characters.
Select Save . Repeat this process for each Quick Text message being added.
Sync the device.
Editing Quick Text MessagesLog in to the Garmin Explore website .
Select MESSAGES .
Select Edit, next to the Quick Text message.
Each message is limited to 160 characters.
Click Done . Repeat this process for each Quick Text message being edited.
Sync the device.
Deleting Quick Text MessagesNOTE: The first three Quick Text messages can be edited, but they cannot be deleted.
Select MESSAGES .NOTE: On mobile browsers, select in the top left, then MESSAGES .
Click Delete .
Sync the device.
Creating and Editing Quick Text Messages Using the Garmin Messenger AppNOTE: The following processes only work with Garmin Messenger app compatible inReach devices .
Adding Quick Text MessagesOpen the Garmin Messenger app.
Select the profile icon or in the top left.
Select Quick Text Messages .
Select Add Quick Text .
There is a limit of 20 Quick Text messages.
Editing Quick Text MessagesOpen the Garmin Messenger app.
Select Quick Text Messages.
Select the Quick Text you wish to edit.
Select Save .
Deleting Quick Text MessagesOpen the Garmin Messenger app.
Select the Quick Text you wish to delete.
Select .
Creating and Editing Quick Text Messages Using the Earthmate AppNOTE: The following processes only work with Earthmate app compatible inReach devices .
Adding Quick Text MessagesOpen the Earthmate app.
Select > Messages (Android™) or Messages (iPhone®/iPad®).
Select (Android) or (iPhone/iPad).
Touch next to the Type Message field (shown below).
Select .
Editing Quick Text MessagesOpen the Earthmate app.
Select .
Select Save .
Deleting Quick Text MessagesOpen the Earthmate app.
Select .
Select .
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
