Wiring Bare Wire Powered Mount for the VIRB Ultra 30
The VIRB Ultra 30 Powered Weatherproof Case includes an attached 10-meter bare-wire cable for direct connection to a DC power source.
Professional installation is recommended. Use an appropriate length of cable for your installation. The installed cable must not be stretched or taut. Tie up or cut the excess cable. If you cut the cable, you must reattach the in-line fuse.
Do not route the cable near pedals, suspension, or any other area that could interfere with the control or function of the vehicle or vessel. Failure to heed this warning could cause damage to the product or cables or result in an accident or collision resulting in death or serious injury.
See the instructions below. These instructions are also included in the box for the Powered Weatherproof Case.
