(2022) Service Bulletin 22021 Rev A: G5000® STC Update for Textron Aviation Model 400A Beechjet Aircraft
PRODUCTS AFFECTED:
All Textron Aviation (Beechcraft) Model 400A Beechjet aircraft equipped with G5000 Integrated Flight Deck, with System Software Version 2091.03 or 2091.04, per STC ST01821WI are affected.
COMPLIANCE:
Optional. This service bulletin is optional and may be incorporated at the owner’s discretion.
PURPOSE:
STC Service Bulletin 22021 provides notification of an update to STC ST01821WI Master Drawing List G5000 Integrated Flight Deck Textron Aviation Model 400A, Revision 13 that includes G5000 System Software Version 2091.05.
  • New equipment options
    • FS 510 Flight Stream: includes Bluetooth and WiFi transceivers; requires Garmin Pilot™ application by PEDs
    • GDR 66 Data Radio: supports both FAA DataComm and Link 2000+
    • GTS™ 8000 TCAS II: includes an ADS-B IN solution and replaces factory TCAS II system
    • GTX™ 345R ADS-B IN Transponder (Rx only capable): provides an ADS-B IN solution (Dual Link Traffic) for factory TCAS II system as well as FIS-B Datalink Weather
    • GSR 56 Iridium Datalink: includes optional cabin phone support with GDL 59 installation
    • GWX™ 75 Weather Radar with 14” Antenna: upgrade to existing GWX 70 Radar (and 12” Antenna); provides 120 scan angle and enhanced color palette
    • GRA™ 5500 Radio Altimeter: replacement for factory radio altimeter
  • Software and configuration updates
    • ARINC 429 and ARINC 717 flight recorder support options
    • Various software updates to support incremental improvements and as required to support the new optional equipment
