Garmin has identified an issue with GPS firmware that causes the time and date to be wrong. A software update is available that resolves this concern. Due to the age of the devices and the complexity of updating, it is not recommended to update unless you specifically need accurate date and time.
What happens if I do not update the eTrex Legend Cx, Vista C, or Venture Cx?
- Position, velocity, and other navigation data will still work
- Waypoint, route and track data will be accurate but will show the wrong date and time
- The time and date will appear wrong on
- Features like Hunt & Fish or Sun/Moon will be incorrect
What are the update limitations?
- Windows Computers
- The update will fail on a Windows 10 computer a Windows 8 or older operating system is required
- We recommend using a Windows 7 computer to run the update
- Mac
- The update may appear to fail on a newer Mac computer running Mojave operating system (10.14). However, if you check the device after the update it should have the correct time and date
Use the options below for steps to update your Garmin.
Click here for steps to update on a Windows computer1. | Before updating your device, you will need to have WebUpdater installed on your computer. If you already have WebUpdater installed, skip this step. | Download WebUpdater | 2. | Connect your Garmin device to the computer with the appropriate USB cable. Note: Avoid using USB 3.0 ports when updating a collar. |  |  |  | Mini USB Cable | Laptop | Desktop |
| 3. | Launch WebUpdater WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater. Windows: Either double-click the WebUpdater shortcut on the desktop (if available), or search for WebUpdater in your Start menu. |  | 4. | Select the desired device from the drop-down menu or click Find Device if your device isn't listed. Click Next. |  | 5. | WebUpdater will display the available updates. Click Next through the following pages to review the software release notes, the software change history, and the license agreement. |
| 6. | Check the box to agree to the license agreement terms and then click Next to begin the update process. |  | 7. | Once the update starts, WebUpdater will display the current progress. |
| 8. | After installing the main update file, WebUpdater will prompt you to check for any additional updates. Click Next. |  | 9. | If additional updates are available click the checkbox next to the desired updates and click Next to install them. Once complete, click Finish If no additional updates were found click Finish |
| | Once complete, disconnect your device from the computer and power it on to make sure the software updates installed successfully. | |
Click here for steps to update on a Mac computer1. | Before updating your device, you will need to have WebUpdater installed on your computer. If you already have WebUpdater installed, skip this step. | Download WebUpdater | 2. | Connect your Garmin device to the computer with the appropriate USB cable. Note: Avoid using USB 3.0 ports when updating a collar. |  |  |  | Mini USB Cable | Laptop | Desktop |
| 3. | Launch WebUpdater WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater. Mac: WebUpdater can be found in the Applications folder in Finder. |  | 4. | Select the desired device from the drop-down menu or click Find Device if your device isn't listed. Click Update. |  | 5. | Review the license agreement and click Agree to begin the update process. |
| 6. | Once the update starts, WebUpdater will display the current progress. |  | 7. | Once complete, WebUpdater will display a message that your device has the latest software. If additional updates are available continue to the steps below. If no additional updates were found, the update process is complete. |
| 8. | Select any desired additional updates and click Update. |  | 9. | Review the license agreement and click Agree to continue. |
| 10. | Wait while the additional updates install. |  | 11. | Once the additional updates are finished, click Done. |
