(2022) Service Bulletin 22029 Rev A: GDC 7400 Pitot-Static Fittings
PRODUCTS AFFECTED:
Garmin GDC 7400 (011-02337-01) units listed in the link below are affected:
https://support.garmin.com/aviation/faq/y3xGso4puD2oOqmO2GU3TA/
COMPLIANCE:
Mandatory
PURPOSE:
Due to a supplier machining defect, the pitot and/or static fittings may loosen within the connector plate. This creates a small path for debris and/or moisture incursion, as well as possible electromagnetic interference.
Garmin Service Bulletin 22029 contains instructions to return the affected product to Garmin.
WARRANTY INFORMATION:
This Service Bulletin is warranty reimbursable with a deadline of October 31, 2022 after which this upgrade will no longer be reimbursable for labor.
Related
