Protect the zūmo XT Motorcycle Mount from Harsh Outdoor Elements
Protecting the zūmo® XT GPS navigator motorcycle mount from the elements will help increase its life.
You can Help Protect the Mount by Following the Tips Listed Below:
  • Keep pins dry and covered with the included weather cap
    • The included rubber weather cap is attached to the power cable as seen below
  • Apply dielectric grease to the pins to create a thin protective coating on the surface of the pins
  • Wire power for the mount to a switched power source to provide power to the mount only when the motorcycle is powered on
  • If water does get into the connection area, blow it out with compressed/canned air
  • Mount the device behind fairing (windshield), if available
These steps will help protect your device and accessories from harsh weather elements.
The Video Below Includes Details on Using the Weather Cap.
