Installing Software Updates to Garmin Dog Products Using WebUpdater
Garmin periodically releases software updates to improve performance, correct operational issues or add new features. Updates are free, and easy to install.
Most Garmin dog tracking handhelds and collars can be updated with Garmin Express™ software, however for those devices that are updateable and not compatible with the Garmin Express program can be updated using Garmin's WebUpdater. For a list of dog tracking and training devices that should be updated this way, refer to the list below:
Important: This product is NOT compatible with Mac OS. Please use Windows version of Webupdater to perform updates.
- Before following the steps below, you must download and install Garmin WebUpdater
- You can follow along by watching the video below.
To Update Your Garmin TT 15 Collar with WebUpdater on Windows:
| 1. | Connect your Garmin device to the computer with the appropriate USB cable. Note: Avoid using USB 3.0 ports when updating a collar. | |
| 2. | Launch WebUpdater WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater. Windows: Either double-click the WebUpdater shortcut on the desktop (if available), or search for WebUpdater in your Start menu. | |
| 3. | Select the desired device from the drop-down menu or click Find Device if your device isn't listed. Click Next. | ![]() |
| 4. | WebUpdater will display the available updates. Click Next through the following pages to review the software release notes, the software change history, and the license agreement. | |
| 5. | Check the box to agree to the license agreement terms and then click Next to begin the update process. | ![]() |
| 6. | Once the update starts, WebUpdater will display the current progress. | |
| 7. | After installing the main update file, WebUpdater will prompt you to check for any additional updates. Click Next. | ![]() |
| 8. | If additional updates are available click the checkbox next to the desired updates and click Next to install them. Once complete, click Finish If no additional updates were found click Finish |
Once complete, disconnect your device from the computer and power it on to make sure the software updates installed successfully. |
