(2019) Service Advisory 1865: Display of Information for Facilities Using 8.33 kHz COM Frequencies
PRODUCTS AFFECTED:
All Garmin aviation systems using a Garmin Navigation or Jeppesen NavData database are affected by this advisory.
ISSUE:
The mandate for COM devices to be 8.33 kHz equipped in Europe has recently become effective. Many Garmin avionics pre-date the concept of 8.33 kHz frequencies and therefore older unit software versions do not provide information for facilities using 8.33 kHz spacing from the navigation database.
PILOT ACTION:
No action is necessary. This advisory is intended for informational purposes only. Affected owners may contact their dealer or OEM to determine if updated unit software is available.
RESOLUTION:
Some systems have upgrades available which allow display of information for facilities using 8.33 kHz frequencies. The systems which can display this information are listed in Table 1 (see Service Advisory 1865).
NOTE: Lack of 8.33 kHz frequency information in the database does not prevent the radio from being tuned to the desired frequency.
